geting the static water table without lifting the pump few "
Rreeuuvveenn
California
need to verify the reading of the plastic tubing (90 psi),
pump puts out some gallons and rests for a day,
1.5HP, 540 feet deep, 3ph, grundfos, 7 years old,
but did not work much,
we are in a sever drought,
thanks a lot
reuven
90 PSI would correspond to 208 ft of head.
So if you could hold 90 PSI of air on your hose, the water top would be 209 ft above the hose bottom.
Is that what you were asking?
Rreeuuvveenn
California
NO.
but thanks for replying
i need to verify that 209 feet above the hose is true,
my boss does not believe my numbers,
pump stops after 10 min, goes dry, current goes down, water does not come out,
as if the pump runs dry,
do not see a check place for measuring the water level,
casong is 6" pump is 4"
thanks
