First of all, please forgive my ignorance...
RE: Gerber Wall Hung, Elongated Top Spud Bowl (Model Number 25-030)
RE: Josam Closet Carrier (Vert w/Left Hand Vent) (Series: 12704)
I work for the Federal Aviation Administration (FAA) and I am the Electronics/HVAC/Power Systems Technician. I got roped into the repair of the above items. A fellow technician found a bowl that was leaking. He tightened the finish hardware and yes, cracked the bowl. Here is the situation...
The Josam prints discuss a 'finished wall' about 5.5 inches the lock nut (hex jamb nut) of the carrier. Does that truly mean a finished wall up to and near the outlet extension? I've got tile placed near the mounting studs and the hex jamb nuts, but no tile near the outlet pipe. The outlet pipe is surrounded by the 'green sheetrock' used for moist places. Can the neoprene gasket be placed right on the sheet rock?
I am learning a lot right now. I know, for a fact, that the bowl was not mounted correctly. The 'backing hardware' for the bowl was not used and basically, the bowl was tightened against the wall.
I am looking for some help, instruction sheets, etc.
Many Thanks,
Many Thanks,
