My forced air heat out of the register is at 102 degrees, what is yours?
Only if you stay out in the sunlight without sunscreen on, it gets to over 120 in the summer in Phoenix in the summer.You could get second degree burns from that.
So you add heat (electric) to your heat pump, ... in Florida? I got me one of those IR thermal guns, less than $50, now I see them for $25, if you ever get the chance try em, they spot energy leaks real easy.speedbump said:I don't have any idea how hot my registers air flow is. Without a heat strip and just using a normal heat pump, I would not think very hot.
I agree, I can get my solar tank up to over 180 degrees in summer, those are glass faced solar panels.speedbump said:I can paint a pipe black lay it on the roof and get the water up to 140° in the summer though.
