I have a powerboss 7000 surge to 12000 gas generator with 1000hrs and it seems to be working ok but I am sure it will give out soon.
https://www.electricgeneratorsdirect.com/PowerBOSS-30220-Portable-Generator/p1056.html
I was given a 6120 surge to 6500 Northstar diesel generator by my grandfather who never used it...
https://www.absolutegenerators.com/northstar-165930-6500w-10-hp-diesel-generator
My question is why will the diesel generator not run my well pump???
Well pump specs are 1hp and it is suppose to run at 4000 watts on startup(currently hooked up to a dual pull 20amp circuit). So my Northstar should run the well pump but it does not. The Northstar runs my cooktop which is a dual pull 30am circuit though??? I have tried shutting off all the breakers except the well circuit and that does not do the trick? Any help would be much appreciated. Thank you.
