Gate valves leaking due to solder/tinning flux
Bass
Chicago
I just built an outdoor shower using gate valves to control the flow at each point (hot/cold/shower head/foot hose) and they all seem to have a very slight leak. I think the trouble with the deal is that some solder or tinning flux must have gotten into the area where the gate sits keeping it from fully closing. Any advice on how to fix this? Do I need to replace them all?
thanks!
B
assuming leak means it dosent fully shut water off. in which case generaly valve is bad. poor quality? inexperianced hands often overheat, best to solder on an open valve. its a bit of a risk most valves at big box store, not that supply houses dont ever sell junk.
maybe something serviceable like a globe that has a washer for easy changing
Mr tee
Montana
Gate valves are famous for leaking a bit. They are meant to normally be in the wide open position and closed for maintainence of the system. If you are using the valves to shut off the water you want something with a washer, a globe valve. A ball valve would also work but it would be harder to adjust the temperature. If you switch to globe valves there are a couple things to know: (1) they are directional, you want to install them so that when shut there is no pressure on the packing, (2) they need to be in the open position when you solder so the washer won't melt.
Tuttles Revenge
2nd what MrTee said. Globe valves are intended for throttling. Gate valves are not.
Dj2
California
Globe valves can control flow. You need globe valves for what you want.
The difference between globe valve and gate valve is in the internal construction.
