Hi all,
I am trying to understand if it is possible to use a gasoline powered water pump to fill a pressure tank. I have an off grid camp on a lake in northern Maine. For decades we have used a gasoline pump to fill a 50 gallon tank that sits on a slight hill above the cabin. The pump sits on the shore of the lake, less than 15 vertical feet above the water, and pushes the water another 60 or 70 vertical feet up to the holding tank, which then feeds our sink via gravity. Our pump is a 3.5hp Koshin/Honda: https://www.koshinamerica.com/shopproductdetail.asp?prodID=14
This has worked well, but we recently hooked up a small tankless water heater, and the gravity from the holding tank does not provide sufficient water pressure to activate the heater. I have temporarily fixed this by installing a small 12v RV pump to pressurize the line, run off a car battery, but what I would really like to do is replace the holding tank with a big pressure tank (maybe 86 gallon, which would give me about 26 gallons of drawdown at 20-40 psi). My question is, can a gas pump like the one that I have be used to fill a standard pressure tank? The specs on my pump say that it can manage 42 psi maximum. So in theory, I could put a pressure gauge on the line above the pump, and run the pump until it reaches about 40 psi, and shut it off. Does that make sense? Suggestions appreciated!
