Update-I tested the system at 6psi and had no loss when I checked on it 30 minutes later. According to the international fuel code it passes. My local code has no amendments to that. 2 hours later I was down to about 5.25psi. I test at 530pm in Texas and it is very hot. 2 hours later the temperature had changed but not too much. I took the tester off, turned on the gas, purged the line, closed the valves, and took one of those gas detector wands (bought at lowes) over the whole thing. The wand did not show any leaks at all. I'm guessing it could have been the tester fastened to the pipe that caused the drop. However, I'm still concerned. Wand showed no leaks and the test passed by code. Am I ok? Or are those wand leak detectors faulty?
