Lefebvres090428
I want to run a section of csst for natural gas to my stove area before I have a plumber test and hook up. The main line comes in from the regulator via black iron and then pretty much Immediately goes to 3/8 copper and runs along the wall for about 15 ft where it turns and runs into the gas fireplace on the other side of the wall. Can I tap into the copper to run the csst up the wall to the attic where I will then run it down the wall to the stove? Or is the 3/8 copper line not sized big enough for the two appliances and I need to run the csst back to where the black iron comes in and tee off of that? Do I need to run the csst inside conduit when ran in a garage on the exterior of a wall inside the garage?
