jcrevz
Switching from electric to gas range. Gas water heater directly on the other side of wall in garage, 3/8" copper tubing (actually probably 1/2" now that I think about it) supply that runs through the crawlspace from the meter on the other side of the house underneath the kitchen. Copper is flared to black pipe for regulator and valve for water heater. Old gas log fireplace on meter side of house tee'd off same line close to the meter, but capped now (wood burning). Not sure of Btu's for the water heater or the range but I could get that later if needed. Can I sweat in a tee on this same tubing, to feed the range? Would this be done under the crawl and stubbed through the floor or in the garage and stubbed through the wall? Extend/tee off the black pipe? What is the typical install for this?
