jpaul
Old boiler with baseboard maybe 1960's, I don't know. Only one zone.
Boiler idle since last heating season. There was a chimney problem...the flue fell. New stainless external chimney now in place.
Went to light but no pilot light, unclogged jet and have beautiful pilot light.
Turn on, call for heat and fires right up then shuts down in a minute or two and I see the temp is 200 degrees. Let cool down fires up, reaches 200 degrees and shuts down.
When calling for heat I heard lots of gurgling so I looked into bleeding system. I have three valves one at the water inlet, one under small expansion tank and the drain valve:
A couple of questions:
How do I bleed this system and is boiler on or off during bleeding. If on, and the boiler doesn't stay on can it sill be bled?
This couldn't be be a thermopile problem, correct?
When the stainless chimney guy was working on the chimney he broke the air vent and it was leaking and he replaced it. Leaked a good amount of water. I asked if the boiler would need to be bled he said it would self bleed.
If it's a matter of bleeding I'd like to beed it and test it…Anything other then a thermopile replacement I'll call someone in but I'd like to have an idea of what the problem might be before I call. Thanks for reading, any comments appreciated.
