Garden Hose Spigot
Discussion in 'Irrigation / Sprinkler Forum' started by Heather Comitz, Nov 5, 2020.
  1. Heather Comitz
    Heather Comitz New Member
    Nov 3, 2020
    FL
    Anyone know how I would go about fixing this? Thanks in advance for the feedback!! :):D:eek:
  2. Sylvan
    Sylvan Still learning
    Sep 23, 2004
    plumbing - fire suppression - boiler inspector
    New York
    Replace it as it not worth trying to make any types of repair
    MASTERPLUMB777 likes this.
  4. WorthFlorida
    WorthFlorida The wife is still training me.
    Oct 28, 2009
    Retired
    Orlando, Florida
    It's sure an oddball one. This spigot is sweated onto a copper pipe as you can see the threads in the wall. If you don't know how to sweat pipe this can be a challenge & calling a plumber maybe in order. I've replaced a few spigots on CBS walls. Generally you need to open the wall a little more and I install a 1/2" FIP Female Adapter Fitting sticking out about 1/2" from the stucco. After the repair fill the hole with hydraulic cement. I then thread on a 1/2" spigot. In the future if the spigot goes bad you just need to thread on a new one.
    [​IMG]. [​IMG]
  5. Sylvan
    Sep 23, 2004
    New York
  6. Heather Comitz
    Nov 3, 2020
    FL
    Yes I’d like to replace it. I’m just trying to see if there’s any way I can do that without having to solder a new one on. Thanks.
  7. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Is there an indoor turn-off valve for that spigot?
    Is that a steel pipe coming through a stucco wall? If so, if that were mine, I might turn that brass/bronze CCW and see what let go. I would not do it for somebody else, because I could get blamed if it does not work.
  8. WorthFlorida
    Oct 28, 2009
    Retired
    Orlando, Florida
    Florida homes are all slab and I’ve never seen a shutoff for spigots here. Only at the church I worked at. The shut off was eight inches from the spigot on the outside of the wall. It never freezes here so they do not need a shutoff for freeze protection, except Texas and look at the mess many are in.
  9. Reach4
    Sep 25, 2013
    Maybe OP is in Crestview, FL. ;) https://www.crestviewbulletin.com/article/20121127/ENTERTAINMENT/311279899
    More seriously, If that is steel pipe, I still might try sticking a big wrench on that brass/bronze and turning. Yes there is a risk. I am not a pro. If it comes loose in the wall, I think that is still OK. You replace that with brass when you put the new spigot in place, or you put the same steel back after tape+dope.
    A magnet will identify steel.
Similar Threads: Garden Hose
Irrigation / Sprinkler Forum Simple garden hose sprinkler on Well pump issue Jun 25, 2016
Irrigation / Sprinkler Forum Running drip line to raised flower/garden bed Apr 30, 2020
Irrigation / Sprinkler Forum Garden irrigation Feb 15, 2011
Irrigation / Sprinkler Forum Garden faucet valve Sep 6, 2008
Irrigation / Sprinkler Forum Garden Works May 13, 2008
