Galvanic corrosion with CSV / PVC bushing leaks
Rmgolob
Indiana
In a previous thread, @Reach4 stated:
"(Brass and stainless) and (brass and copper) are normally thought to not have galvanic corrosion problems."
I'm not disputing that at all, but....
"Normally" and "Problems" offer at least a level of concern greater than Zero.
My house has all original copper from 1976 (45 years old.)
I'm certainly not concerned about corrosion with a brass fitting connected to the stainless CSV body.
But I would be concerned that that dissimilar connection could lead to corrosion elsewhere along the copper piping.
Yes? No? Maybe?
I say all this because in the pictured set up I have PVC threaded bushings in each side of the CSV. I know why people do not like threaded PVC - A bear to keep from leaking.
That is the only 2 spots in my installation that leak.
I suppose I did not tighten the bushing enough, but going into stainless, I figured there was the potential to compromise the PVC threaded into the much much harder stainless.
My "fix" for the outlet would be to replace the 1" x 3/4" PVC bushing and 3/4" Sharkbite with a single 3/4" x 1 " NPT Sharkbite.
That would certainly work, but do I then worry about the galvanic corrosion?
Is it OK to CRANK the bushing into the stainless CSV threads?
Anyone else experience this?
Anything else?
As always, Thanks in advance.
I don't see brass to stainless as being a problem.
How tight is the PVC to the stainless now? Maybe snug it up a bit more?
Rmgolob
Indiana
Thanks - I THOUGHT it was tight, but perhaps not....
I'll try that first.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Need a good backup wrench to be able to tighten the bushings better. Get them as tight as needed and use Teflon tape with pipe dope on top of that if you want.
What material is that piece of black-colored pipe?
