Furnace capacitor testing
Plumber69
Prince Rupert, British Columbia
Will this multimeter test capacitors? If so how do you test them. I'm more referring to furnace capacitors 5mf to 10mf
Yes and no.
For a qualitative test, put the meter in the 20 meg position. Expect the display to show non-infinite briefly when you connect the probes to the isolated terminals. Then back to infinity. Reverse the leads, and get a slightly less brief non-infinity.
But to measure the capacitance, you need one with a capacitance setting.
WorthFlorida
Solutions
Orlando, Florida
Most caps for motors are electrolyte, a liquid inside the cap. When they go bad generally they swell near the blade connectors are or they leak oil. Some have a blow out valve. I never had a cap tester, I always used a meter like yours.
