Hi! I think I already know that this shower needs gutted. But really, it will be rarely used and there just is not budget for it at the moment. And except for this stupid drain its in really great shape, just needs a good cleaning.
Here is the situation (and picture):
It is a fiberglass shower installed in 1983 when the house was built. Shower is still in great shape as is the rest of the floor except right there at the drain, amazingly enough.
It is in the basement but they put a plywood subfloor above the cement. So the pipe in there is ABS, 2 inches wide, they cut a hole in the subfloor , put the pipe in and it immediately elbows off to who knows where and connects to who knows what, presumably the main drain. The strainer just sits on it, loose. BTW, this is the only ABS pipe we have found in the entire house, everything else is PVC. So why in the world they did that is beyond my wildest imagination.
I suppose the temporary and easy fix would be to silicone or epoxy the heck out of that wood area surrounding the pipe so it would quit eating away at the wood or run the risk of leaking under it. But then the strainer would just be sitting loosely on there still or I would have to permanently caulk that on and then if anything ever did go wrong it would for sure be an entire gut job.
So I am trying to figure out some way to put a real flange drain and strainer in there without having to gut the entire shower. Is that even possible? Thanks for any help with this.
PS: 62 year old female DIYer
