Hi
The pipe from my well to the house is frozen. The tech has come and unattached the pipe from the fitting that goes to the pump and the pump pumps water so it must be frozen between there and the house.
He noticed that i had put up a car shelter over the path of the pipes and reckons that no snow insulation over the ground there has made them freeze-I live in Quebec and we have had a pretty cold winter so far.
He will be coming back to thaw the pipe and has said that even though the temperature is now much warmer -still around -15 to -20 degrees c. that it will freeze again if it is not kept moving because the ground around it will be frozen. The well is not very efficient so running water constantly wouldnt work. He has suggested drilling a hole in the pipe that comes up the well so that the water then drains back into the well?
My question is, does this seem like a good solution-if the pipe between the house and the well slopes towards the house, wont the water stay in the pipe? Also does that seem accurate that the water will freeze again. it has never frozen before and I have had the car shelter up 2 out 0f 4 winters although this winter has probably been the coldest.
thanks for any advice
NB (I have 2 wells that have the pipes join up somewhere underground and the enter the house and the other one is still working so I know all other elements of the system are working)
Warren
Warren
