Frozen pipe had been drained
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by LisaW, Feb 25, 2015.
  1. LisaW
    LisaW New Member
    Oct 26, 2004
    District of Columbia
    Hi. In the fall, I drained my outside line and shut off the interior valve that provides water to the outside line. I still had a burst this winter in the outside line and there was moisture seeping through the drywall - this gave me the clue to the break. When I turned the valve back on to test for a break, water gushed out the wall as I would have expected. Would a drained line with a shut off valve still have had water in it to leak and show moisture in the drywall? Thanks.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Assuming this is a frost-free faucet and you left a hose connected. If so, that prevented the water from draining.
  4. LisaW
    LisaW New Member
    Oct 26, 2004
    'Thank you, but no - nothing attached. In the fall, I turned off the valve to the line, opened the faucet until all the water came out, then closed the faucet.
  5. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    My guess, based on your new info, is that you do not have a frost-free faucet, and that your shutoff valve leaked enough water through to fill the pipe that froze. If you had left the spigot open during the winter, that would have been less likely to happen, I think.
    Anyway, replace the spigot with a frost-free spigot, and that problem goes away. Maybe do that to the other spigot too, if you have one.
  6. Terry
    Aug 17, 2004
    It may be that the shutoff valve does not close all the way. In that case, leaving the outside faucet open to drain may be better.
    Normally, if the isolation valve is off, and it has been drained down, you're fine.
    Lateley I have been replacing those broken sections with PEX. It has a bit more give when freezing.
Similar Threads: Frozen pipe
Plumbing Forum, Professional & DIY Advice Frozen pipes, Winter 2018 pictures Jan 3, 2018
Plumbing Forum, Professional & DIY Advice Cold Water in Bathroom - May be frozen pipe Jan 2, 2018
Plumbing Forum, Professional & DIY Advice Frozen pipes Apr 4, 2015
Plumbing Forum, Professional & DIY Advice Unsolvable Problem? Frozen pipes at end of line behind shower above unheated garage Mar 21, 2015
Plumbing Forum, Professional & DIY Advice Easiest way to insulate frozen pipes on exterior wall? Feb 17, 2015
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
