walkeasy
HI! I have been reading other threads and have been putting together various ideas. Now I am looking for input.
I had a well installation completed on Sept 2016.
It has been under light to normal use for 3 person household since installation. I have horrible water quality and have since installed a spin down filter and 3 other large filters, when new the water is also fresh and clean.
I have noticed at various times, I have to clean the spin down filter every 2 weeks or so, manually, as there is a build up of mud and sand so thick water flow stops.
Other times I can get by with on a quick scrub once a month.
I think this means that either
- 600 ft deep
- 1 GPM yield
- Static water Level at 85 Ft
- 252 ft of heavy duty iron casing ( I seem to remember both 10" and 6" casing but can't find it listed
- I can't seem to find depth of pump but I do remember its somewhere between 345 and 450 feet
- I have the largest pressure tank on the general market
- my well is collapsing and or changing shape and stirring up the particles
- My pump is right on the water level at times and causing turbidity
- I'm cycling too much water for my well to support
