Frame Up
Sylvan
Still learning
New York
Really a nice job installing the PVC combination Wye and 1/8 bend LTTY
Should give you years of trouble free service . Nice to see you did use shielded couplings
Very professional installation
Thomas K
Opelika, al
Work completed as of this weekend. Some studs not fastened to plates because I want to bore all needed holes and dry fit pipes before making everything permanent. Black marker lines on studs are exactly 20" above "finished" floor height. Wouldn't you know it, left sink drain of two sink vanity lines up exactly with marked stud at left. I don't know whether to move stud over enough to clear pipe, or move pipe over and adjust sink trap to line up. I thought about notching 2 x 8, but it would be a long notch, too much for code.
If I use double fixture tee in photo, I will have to use a 2" 90 degree spigot x hub street elbow between fixture tee and drain pipe because it's going to be a tight fit. Either that or use two street sanitary tees with twin vent pipes.
