For ever action there is a reaaction
How many others found low flow to create work
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 0 0.0%
  • Total voters
Sylvan
Still learning
New York
NYC in their wisdom to conserve water paid master plumbers to install 1.5 GPF toilets and install flow restriction in faucets
This turned out to be a gold mine for the plumbing industry and lawyers
The flow restrictors cause lots of scalding incidents so being an expert witness added to my bottom line
The the lack of scouring action in main sewer and waste lines allowed for premature failure do to sulfuric acid fumes and other types of sewer gases
Then there was the stoppages being created
Sylvan
Still learning
New York
A college in Manhattan contacted me regarding a chronic problem with one leader line constantly backing up
They told me this has been ongoing before 1965 . .
They college called several Roto franchises a dozen plumbing companies and so called drain cleaners and all of them did the exact same thing
when I went to look at the job one of my mechanics said he would try to snake it or water jet the line from the roof drain
I told him "insanity is doing the same thing over and over and expect different results as EVERYONE tried it from the roof"
I told him get some jack hammers and start open the wet column starting about 2 feet off the floor
Low and behind there was a cast iron test tee installed and the installers never bothered to remove the 4" x 3/4" brass reducer
We cut out the tee installed proper clean out and told the college to install an access door
CRAZY how many years this has been going on and not a single contractor though outside the box
WorthFlorida
Solutions
Orlando, Florida
NYC in their wisdom to conserve water paid master plumbers to install 1.5 GPF toilets and install flow restriction in faucets.
Around 2007 South Florida Water Management District instituted strict water usage regulations. All local code enforcement agency's were required to issue citations for irrigation watering during the restricted days and times. I myself was fined for using my irrigation well. Neighbors were calling on neighbors, it was crazy. The big problem came about that the water companies revenue dropped so much that everyone of them had to raise the rates to cover the cost. The usage went down and the bills went up and of course when enforcement's were relaxed, the cost of water never went down.
