Foghorn when washer stops filling
kelleyrichard
When the water turn off in the washing machine there is a very loud humming from the pipes in the house that has never been there before. It actually sounds like a foghorn. It seems to be coming from the plumbing in the bathroom next to the laundry room. When the water in the washer turns off it is very abrupt (the cold and hot hoses jump). Also, it is also cold here for the first time this year (around freezing, cold for the pac nw). What could be causing this? Is it the sudden change in pressure when the water turns off? I so how do I fix that?
Thanks
Cass
You may have a PRV (pressure reducing valve) installed. It would be near the point at which the water line comes in the house. Check and see if you have one. If you do fill the washer and stand near the valve when the washer turns off and check if the sound is coming from it. If so have it replaced. I liken the sound to a dieing cow on the ones I have replaced.
