Flushing tankless voids your warranty
Discussion in 'Tankless Water Heater Forum' started by Aristoc, Oct 31, 2019.
  1. Aristoc
    Aristoc New Member
    Oct 11, 2019
    Ontario
    I was told flushing your own tankless voids the warranty.
  2. jadnashua
    I'd want to see that in writing. It sounds like an installer guaranteeing a steady income. I can see where NOT flushing one could void the warranty, though. By the nature of the things, you will get mineral deposits inside unless you have perfectly soft water. That can and often will degrade the performance, possibly to the point where it doesn't work any more. IT depends on your water makeup how long or if that will occur.
  4. Aristoc
    Aristoc New Member
    Oct 11, 2019
    Ontario
    I was shocked to hear it from my installer too. Then when I read through the manual, it says it there that a qualified service technician needs to do all the work. I can copy and paste this from my Navien manuals later. Don't know about other brands though.
  5. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
  6. Aristoc
    Aristoc New Member
    Oct 11, 2019
    Ontario
  7. Jbrk
    Jbrk New Member
    Oct 20, 2019
    Toronto
    It miffs me when there's a blanket statement like that. I set up a warranty with HTP. They asked if I was the homeowner, you have to state that you're the builder and they seem fine with that.
    I don't know exactly what "qualified" installer means. You could be a qualified plumber and have never seen a tankless before. Don't mean the system is going to last longer or not short cycle with hand washing. You could also be the best plumber but no gas ticket, well they're not qualified to put one in are they? Or be a gas tech that slap some plumbing together with sharkbites, that's qualified right?
    I think that statement about maintenance is in there maybe so homeowners that never descale, make a warranty claim, and say they've descaled every year. Well there's no proof at that point. Vs receipts as proof from a "qualified" technician
  8. Reach4
    Sep 25, 2013
    I suspect they distinguish between maintaining and service. Did the manual you were looking at have a "Flushing the Heat Exchanger" section? If so, does it contain these words?
    Flushing the heat exchanger is a somewhat complicated procedure. Read the following instructions carefully before attempting this procedure. If you are uncertain about any of the steps in the procedure, contact an authorized technician or licensed professional. Keep in mind that improper maintenance can void your warranty.
    What you quoted looks similar to https://www.navieninc.com/app/W1siZiIsIjIwMTgvMDQvMDUvMjMvMDEvNDEvMDg5YTExMzMtMjM2Zi00MmMwLWJmYjEtYjY4YTczM2RlNzU4L05DQiBVc2VyJ3MgSW5mb3JtYXRpb24gTWFudWFsIChFbmdsaXNoKS5wZGYiXV0/NCB%20User%27s%20Information%20Manual%20%28English%29.pdf?sha=da45f235a44461e0 which has those words.
    Here is a snip from the table of contents: img_3.png
  9. Aristoc
    Aristoc New Member
    Oct 11, 2019
    Ontario
    Qualified means whatever navien wants it to mean.But I think the word 'qualified' is refering to service and installation. Not to regular maintenance.
    My unit is a NPE 210A and I am reading from it's manual. When I called my installer for a problem, they said that I never had called them to do a flush, so I said I have done them myself. They said it has to be done by a "qualified .....etc etc." to keep the warranty. I questioned that. So I startred reading the Warranty on the Navien site and the Navien Users Manual. I am starting to think that my installer is confusing the word "servicing" as written in the manuals with "maintenace." I could not find where it says that "maintenance" such as flushing has to be done by a qualified installer. Not even in the online warranty. So I think my installer is wrong on that.
    I did call navien customer service and the person on the line questined whether or not I could do a flush myself because he said it is "complicated" and you need 'special equipment" . I told him I had the equipment and could do it myself. He wasn't so sure.
  10. Reach4
    Sep 25, 2013
    Was I also reading from your manual for section 4.3?
Similar Threads: Flushing tankless
Tankless Water Heater Forum Tankless flushing with recirculating pump Dec 6, 2015
Tankless Water Heater Forum Rinnai R94LSi Flushing Problem May 25, 2020
Tankless Water Heater Forum Our Eternal Tankless GU26 died after 13 years Wednesday at 1:35 PM
Tankless Water Heater Forum Tankless vs indirect heat May 18, 2020
Tankless Water Heater Forum Tankless hot water heater in addition to HPWH May 2, 2020
