EddieRock
I have 1 zone that is part of my boiler that services in floor heat. the loop has a circulator pump inline between the inlet and the valve where I put the hose to drain. This zone is the highest one and I think is full of air. I have no heat in just this zone. It has the pump because there is also a mixing valve that remixes the loop to reduce the heat for the in-floor heat.
I have two questions:
Can I flush that zone with the circulator pump in-line or do I need to bypass it somehow?
Also, do I need to open the mixing valve all the way so when I flush the zone, the water doesn't take the shortest route to exit the system instead of flowing through the infloor system?
thanks in advance for your quick reply!!
EddieRock
EddieRock
