Hi,
So what are my options ...
Bone Char ?
Activated Alumina ?
Any other POE solutions beside Whole House RO ?
EDIT:
I found some claims of a media that is capable of removing fluor
Thx
Bone Char ?
Activated Alumina ?
EDIT:
HealthGuard System HG - FluoriGone - FG refers to a proprietary blend of Fluoride, Arsenic, Anion and Cation Removal Resins used by San Diego Pure Water (SDPW) to remove Fluoride in residential applications. This media is NSF Certified and ANSI Certified for Water Purification Use. This media is Re-Generated with Sodium Chloride (Salt) and Re-Generates in a manner similar to a Softener. In counties that have out-lawed salt re-generated water softeners these systems are not allowed.
The Major Advantages of HG: 1. Can remove Fluoride to relatively high levels (91%+), 2. FG can be effectively used over and over again through Salt Re-Generation; this media can be used for 10+ years in constant service. 3. This systems overall cost is 1/2 that of other methods of Fluoride Removal.
The Major Drawbacks of HG: 1. Requires maintenance and inspection at least every 6 months, 2. Requires salt monthly for re-generation, 3. Adds Sodium to the water as it removes Fluoride, (A health issue), 4. Requires the use of a Reverse Osmosis Filter for Drinking Water.
General Maintenance: POU – This media cannot be used as a POU solution, as a POE solution this media is highly effective and extremely inexpensive to operate. FG resin will last up to ten years.
Thx
