Hello all,
I want to put in a 2.0 - 2.5 cu ft carbon tank filter. I am uncertain if I have enough flow for the 10+ gallons/minute for backwash. I have two water meters to the property. I get 20 gallon/minute from my sprinker system side. When I measure flow on a house hose bib, I get 5 gallon/minute with the PRV at 60 psi and 7.5 gallon with it opened to 80 PSI. Currently there's a small PRV I plan to replace. My question is; Is the small PRV I have now combined with reduced frow through 1/2 pex and a hose bib enough to account for the difference in flow rate between my house and sprinker system flow rates. IE...if I put 1" PVC/PEX-A from the street to the carbon tank with a larger/higher flow rate PRV, will this likely give me 10+ gallons per minute, or should I go with a 2.0 cu ft tank. My assumption is that my reduced flow rate will resolve with a bigger PRV and 1" pipe, but would hate to get a 2.5 cu ft tank and not be able to backwash it.
