Hello again wise plumbing masters; I have a couple of questions for you about my bathroom remodel.
My bathroom looks like this currently:
My plan is to put down some 3/4 plywood over the angled floorboards, put Ditra (+heat) over that and then tile.
Tile
Ditra (+heat)
3/4Ply
Floorboards
This should work ok, yes?
My question is regarding the toilet flange; I have some 4inch abs pipe sticking up thru the floor; I'm ok to attach the flange over the finished tile once I'm done.
When I screw the flange to the subfloor, it's going THRU the tile and thru the Ditra; doesn't that compromise the waterproofing? Won't water just flow down there and mess up my subfloor?
In fact, how do I make sure that water cannot just flow down the side of the ABS Pipe that the flange is attached to? I mean, if kids spill a lot of water on the floor, won't it go under the toilet and down that space?
I've searched a bit and I've not seen a real answer for how to waterproof the inside AND outside of the toilet flange hole.
Edit: I'm not sure I explained it very well, so I made a picture to illustrate what I mean. How do I avoid this?
As always, I appreciate all your help, wise plumbing elders!
Cheers
Jan
Tile
Ditra (+heat)
3/4Ply
Floorboards
Cheers
Jan
