Floor leveler for OSB flooring?
Slugger740
Atlanta
I need to level an OSB Advantech subfloor that is out of lever in my bath renovation. The area to be leveled is roughly a half circle area with the width of the area being approximately 6' (aka 3' radius). The lowest point is the midpoint of the straight side of the half circle and is 1/4" below level.
After reading up on floor levelers (Level RS and Laticrete's NXT Level Plus), it seems that you need a minimum of 1/4" of leveler over OSB for the Laticrete and 1/2" + mesh using Level RS.
Is there a self-leveler that can go from 1/4" to feather edge over OSB?
If not, my other option is to use Henry's 549 and screed it.
FYI -- will be putting LVP flooring over the this.
thanks
You could try this stuff https://www.ardexamericas.com/product/ardex-liquid-backerboard/
Note, because of surface tension, a self-leveling material does NOT self level...it needs help. Think pouring batter into a pan to make pancakes...it doesn't expand to fill the pan and like a water drop on a waxed floor, will end up with a bead unless you manipulate the stuff.
