Plumber69
Just busted up concrete to fix sewer line. Floor drain has no ptrap. Is a floor drain recommend in a laundry room. If sewer backs up its coming out there first.
I said I busted up the cement, its clearly tied in the sewer. My question was, is it recommended a floor drain in a laundry roomThe drain might just go to a dry well, rather than to the sewer. In that case, it probably wouldn't need a p-trap.
I am surprised that the bell trap is permitted in NYC. It seems perfectly functional to me, but so many codes specifically disallow those and drum traps. Drum traps are also functional for some uses, and would be nice for adding a standpipe for a softener without having to install a vent.We do install floor drains in laundry rooms with traps Casi Iron with a bell to prevent odor or sewerage from overflowing the drains .
Just remember to pour water into the drain so the trap seal does not evaporate
The floor drain is not required, however is a good idea.
Here in Canada, if the floor drain ties into the building drain, and if on the upstream end up the connection to the building drain the stack terminates 3” to open air from top to bottom, then the floor drain does not require a vent.
