Nonlinear
I live in a townhouse complex where all the AC units are on the rear patio. The AC units sit on top of a wood "deck" which in turn sits on a waterproof membrane. The wood "deck" is not fastened to anything.
When the waterproof membranes start to go and need to be repaired or replaced I'm wondering how this is going to work due to the AC units. My thought is that if the AC unit can be suspended, maybe by running some lumber across the top of the wood dividers and hoisting it up with some rope, the wood "deck" underneath can then be moved to allow access to the membrane.
My question is how flexible are those copper hard lines that run from the AC unit to the exterior wall? If the AC unit is hoisted up several inches are they likely to break?
Along those lines, is there such a thing as a flexible hose that can be used between the AC unit and the exterior wall instead of copper tubing?
