Fleck softener not showing proper water usage
Every night at 2am the softener asks if it has enough capacity remaining to make it thru the next day. If not, it regenerates. The RS is reserve setting. rc says use RC (reserve capacity) in gallons. RS=sf is safety factor in percent.
They do the same thing... define how much reserve.
The display number counts down to zero. If at 2 AM, the display says 3, it waits until the next day to check again. So the number does not include the gallons that are in the reserve.
Dan Bixler
Minnesota
Yes. Sorry. I see my mistake now. I changed sf to rc and set the reserve to 120. All the other settings are set to what you posted.
Dan Bixler
Minnesota
Thanks a ton for your patience and insight. I was quite frustrated with what the settings should be.
