After reading through numerous helpful threads, I decided to ask for your advice because I cannot get my softener to function properly. Specs and settings are as follows:
Fleck 7000SXT
64,000 capacity, 2.0 cu ft
City water, 14-17 grain hardness depending on when I test it.
4 adults, 1 todler
#0 Red injector
0.125 BLFC
DF = Gal
VT = dF2b
CT = Fd
C = 40.0
H = 22.0
RS = cr
DO = 28
RT = 2:00
B1 = 8.0
Bd = 110.0
B2 = 5.0
RR = 5.0
BF = 35.0
FM = t1.2
We have had the softener for about a year, and it worked OK for the most part. We were getting some harder (6 grain) water at the end of the cycles, so I decided to inspect the hoses to make sure nothing was clogged. Everything worked fine for one cycle after that, but now it is not drawing any brine whatsoever during the BD cycle. It won't even draw from a cup if I disconnect from the float switch. I have checked for clogged drain lines and cleaned the injector and blfc.
Do my settings look OK? What else should I check to figure out why the system is not drawing any brine?
Thanks\
Fleck 7000SXT
4 adults, 1 todler
#0 Red injector
0.125 BLFC
DF = Gal
VT = dF2b
CT = Fd
C = 40.0
H = 22.0
RS = cr
DO = 28
RT = 2:00
B1 = 8.0
Bd = 110.0
B2 = 5.0
RR = 5.0
BF = 35.0
FM = t1.2
Thanks\
