ditttohead
Water systems designer, R&D
I was referring to post 30.
As to lubricants... most all NBR, Butyl and other "rubber" O-rings should be lubed, silicone seals are water lubricated. Clacks intenal piston contact seals are silicone which do not use a lubricant, all other o-rings in the Clack valves can and should use lubricant. The right lubricant is critical, see the attached product bulletin from 2006. http://www.pentairwatertreatment.co...nt/Bulletins/529-Lubricants on Components.pdf , and again from 2001 http://www.pentairwatertreatment.co... Water Treatment/Bulletins/376-Lubricants.pdf
