Fleck 5810SXT Programming - Softener w/ GAC
TxHr
Texas
Hello,
I recently had to replace my old faithful 7000SXT with a 5810SXT.
My tank is a 13x65 mid plate Vortex tank w/ 1.5cu 10% cross link resin in the bottom (48,000 grain capacity) and 1.5 GAC in the top, all controlled by a 5810SXT.
That said, I could use your help programming this setup, as my injector, brine and drain are different than my 7000.
5810SXT is setup:
Injector #1
BFLC .25
DLFC Button 3.5
I am also wondering if the above is even correct, given the size of my setup? I have the original blue injector, .5 BFLC and 4.0 DLFC from my 7000 should you guys recommend I go that route (or from what I’ve read, I should be running the yellow injector, .5 BFLC and 4.0 DLFC).
Here is what is input in the controller (and what I could use your help with):
DF: GAL
VT: 5810
RD:
CT:
C: 48x 1000??
H: 38
RS:
RC:
DO:
RT: 2:00a
BW:
BD:
RR:
BF:
FM:
RE: OFF
VR: OFF
I’m using Dixie Crystal iron fighter salt, as I am on well and have the propensity to pull iron (I’ve accounted for this in my hardness). We are a family of four and typically consume around 200 gal/day.
Thank you in advance,
Brandon
ditttohead
Water systems designer, R&D
Ontario California
DF: GAL
VT: 5810
RF:DF1B
CT:Fd
C: 36x 1000
H: 38
RS:cr
DO:28
RT: 2:00a
BW:6
BD:80
RR:6
BF:16
FM:t1.2
RE: OFF
VR: OFF
TxHr
Texas
DF: GAL
VT: 5810
RF:DF1B
CT:Fd
C: 36x 1000
H: 38
RS:cr
DO:28
RT: 2:00a
BW:6
BD:80
RR:6
BF:16
FM:t1.2
RE: OFF
VR: OFF
Thank you so much!
Should I run the blue injector w/ .5 BFLC and 3.5 DLFC or yellow injector w/ .5BFLC and 4.0 DFLC?
Thanks again,
Brandon
