Bill Lundgren
I need some help with my new install. I purchased a 60,000 Fleck 5810 XTR2 and have the following:
Media 2CF of Purolite SST 60
Downflow
12x48 Resin Tank
BFLC 0.25gpm
Injector 0
Drain Flow 3.5
Brine Tank 15"x17"x36"
Hardness 30 grains (includes 0.5 for iron and 0.5 for manganese)
Salt Dosage 12pcf (provided by seller, based on Purolite SST60)
Reserve 300 Gallons
Instructions during the install said that I didn't need to install gravel since my tank was 12" diameter or less. The seller sent me gravel. I contacted seller and they said to go ahead and also install the gravel. So I installed the gravel and the 2 CF of resin. Differing instructions from the seller said the tank should be 1/2 to 3/4 full. I have only 11.5 inches clearance from the top of the tank to the top of the resin.
I've been through about two cycles. I noticed when I showered that the water was hard. I looked at the softener and had 300 gallons left. I got my Hach Kit out it measured 29 Grains of hardness. So I manually ran a cycle. Below are the readings:
[12" of brine in the brine tank]
Backwash 10 min
Draw 1 hr [4" left at bottom of tank]
Rapid Rinse 10 min
Tank Refill 12 min
Display readout says I have 1496 Gallons to use
Questions:
1. Is 11.5 inches enough clearance in the tank for expansion of the resin? I shined a flashlight during backwash and it looked like the resin got to the top of the tank after 3 minutes.
2. What could be the cause of the breakthrough?
Bill
Downflow
12x48 Resin Tank
BFLC 0.25gpm
Injector 0
Drain Flow 3.5
Reserve 300 Gallons
Backwash 10 min
Rapid Rinse 10 min
Tank Refill 12 min
Questions:
Bill
