Fleck 5800 Programming Help
jaeisber
Indiana
I recently installed a new Fleck 5800 Upflow system with 48,000 Grain 10% crosslinked resin. I decided to replace my previous softener (5600SXT / 48,000 grain) after resin failure caused a drop in water pressure. It was an older system, so I decided to replace the system rather than replace the resin. Prior to the resin failure, I had no issues with water softness. My settings were:
RF - dF1b
CT - Fd
C - 30x1000
H - 25
RS - rc
RC - 180
BW - 6
BD - 64
RR - 10
BF - 10
FM - t0.7
The 5800 came unconfigured, so I initially started with similar settings (minus RF, that was set to UFbd). However, water does not appear to soften at all and remains hard. Does not feel slippery like I expect. Tested water hardness is high, ~35gpg. Not looking to get it to 0, but certainly something significantly lower. I've tried adjusting the Hardness up higher, but that did not change anything. Looking for some help to get my settings right. Family of 4 (2 adults, 2 children), ~180gal/day usage.
Any and all help is greatly appreciated!
What are the two numbers on the green sticker? Are there some decimal points?
I would expect the second number to be about 3x the first number.
35 grains is a lot. If that is accurate, you should have gotten a much bigger unit. City water? With the high hardness compensation added, expect to regen about every 3 days. Maybe you should re-measure your hardness with a Hach 5-B kit.
Your back wash rate is lower than usual. I suspect you either have fine grain resin or a turbulator.
The big change in the numbers is for brine fill. Also note that the brine draw is longer, and should be 90 to 100 minutes with your violet 00 injector
5800SXT System info (not programmed)
salt lb/cuft​
7​
A choice ( efficiency vs capacity)​
BLFC​
0.125​
Brine Refill rate GPM​
cubic ft resin​
1.5​
Same as (nominal grains/32,000)​
Raw hardness​
35.0​
including iron etc​
Estimated gal/day​
240.0​
60 gal per person typical calc​
Est days/regen​
3.3​
presuming days each use reserve capacity​
Fleck 5800SXT Settings:
DF​
Gal​
Units​
VT​
5800.0​
Valve type​
RF​
UFbd
Upflow with your piston​
CT​
Fd​
Meter Delayed regen trigger​
C​
33.1​
capacity in 1000 grains​
H​
42​
Hardness grains after comp factor​
RS​
rc​
rc says use gallons vs percent​
RC​
240​
Reserve capacity gallons​
DO​
30​
Day Override (typ 28 if no iron/Mn)​
RT​
2:00​
Regen time (default 2 AM)​
B1​
6​
Backwash 1 (minutes) [3...10]​
Bd​
90​
Brine draw minutes​
B2​
4​
Backwash 2 (minutes)[3...10]​
RR​
6​
Rapid Rinse minutes [5...10]​
BF​
28​
Brine fill minutes​
FM​
T0.7 ??​
check​
Revised based on number from https://terrylove.com/forums/index.php?threads/help-for-programming-fleck-5810.82673/#post-595983
The less salt per cubic ft, the more salt efficient, but more hardness breakthrough.
BLFC 0.125
cubic ft resin 1.5
Alternative capacity (C) and brine fill (BF) pairs. Round C down.
lb/cuft C= BF= grains/pound of salt
5.0 28.7 20 3820
5.3 29.4 21 3736
5.5 30.2 22 3655
5.8 30.9 23 3578
6.0 31.5 24 3503 #less salt use, regen a little more often
6.3 32.2 25 3431
6.5 32.8 26 3362
6.8 33.4 27 3295
7.0 33.9 28 3231 #selected for above.
7.3 34.5 29 3169
7.5 35.0 30 3110
7.8 35.5 31 3053
8.0 36.0 32 2997 #Maybe a better choice for softer water.
8.3 36.4 33 2944
8.5 36.9 34 2892
8.8 37.3 35 2843
9.0 37.7 36 2795
9.3 38.1 37 2748
9.5 38.5 38 2703
9.8 38.9 39 2660
salt lb/cuft​
7​
BLFC​
0.125​
cubic ft resin​
1.5​
Raw hardness​
35.0​
including iron etc​
Estimated gal/day​
240.0​
Est days/regen​
3.3​
DF​
Gal​
Units​
VT​
5800.0​
Valve type​
RF​
dF2b​
Downflow, Double Backwash​
CT​
Fd​
C​
33.1​
H​
42​
RS​
rc​
RC​
240​
DO​
30​
RT​
2:00​
B1​
6​
Bd​
90​
Brine draw minutes​
B2​
4​
RR​
6​
BF​
28​
Brine fill minutes​
FM​
T0.7 ??​
check​
BLFC 0.125
cubic ft resin 1.5
5.0 28.7 20 3820
5.3 29.4 21 3736
5.5 30.2 22 3655
5.8 30.9 23 3578
6.3 32.2 25 3431
6.5 32.8 26 3362
6.8 33.4 27 3295
7.3 34.5 29 3169
7.5 35.0 30 3110
7.8 35.5 31 3053
8.3 36.4 33 2944
8.5 36.9 34 2892
8.8 37.3 35 2843
9.0 37.7 36 2795
9.3 38.1 37 2748
9.5 38.5 38 2703
9.8 38.9 39 2660
Thank you. I will update my settings when I get home from work.
As for 35 grains, yes, I know it is a lot. City reports a low of 20 and a high of 35. City gets the water from a heavy limestone area and is notoriously hard. My previous system was the same size, just with a Fleck 5600. I had no issues with water softness or frequent regen, so I just went with the same size with the new system (hindsight 20/20 now).
