Gqflyaznguy
I currently have the fleck 5800 lxt valve. I recently started getting salty service water and tech support told me I needed to replace the piston and seals because there was water leaking from the drain port. There was about a drip every few seconds. So this weekend I installed a new piston and seals kit but I’m still having the same problem. I lubricated all the orings and piston before install. Is there anything else that could be causing the leaking water? Maybe the piston is not seating properly after regen?
