After having resolved with members help the "no brine draw" issue now I face one more hurdle to soft water: the flow meter is not working. I checked the sensor with a magnet and I see the flow indicator. The problem seems to be with the turbine itself. It is not stuck as I can turn it manually with a small screwdriver but when I blow into it it won't spin freely.
Is there a way to dismantle it to clean it or is the only option to buy a new one if high pressure water does not dislodge whatever is causing the shaft not to spin?
thanks again for your help.
