J. Walter Weatherman
Hi all,
I recently had a Fleck 5600SXT 48k unit installed. The system is currently being used to clean up well water, which contains a small amount of iron / manganese. I am familiar with the concept of salt efficiency, and considerations related to iron, resin and regular backwash, but am hoping someone more experienced with these units might be willing to provide a little guidance in programming the device to the best possible settings. Specs are as follows:
Fleck 5600SXT 48k, fine-mesh resin @ 1.5lb
PH: 7.5
Hardness: 16GPG
Iron: 0.2
Manganese: 0.16
(adjusted Iron & Manganese values are included in total hardness calculation, above)
There are two people in the house, currently using about 125-150 gallons per day (combined total).
I understand that I should reprogram the unit to use six to eight pounds of salt per regeneration, and that doing partial recharge of a larger unit is more efficient than fully charging a smaller unit. From what I have read, it seems like adjusting (reducing) the "C" (capacity setting) on the unit may accomplish this, but hoping someone can confirm, or provide values for this and other associated settings that may need to be adjusted (brine fill, etc.).
In consideration of iron and manganese volumes above, I would also be interested in any recommendations regarding how often I should backwash the unit, or if/how I should program the override. To be clear, I am not opposed to reducing the capacity so that salt use is reduced and backwash naturally occurs on a more frequent basis, particularly if this would benefit the unit.
People on these forums seem to have some good experience - any recommendations are welcome. Thanks in advance!
PH: 7.5
Hardness: 16GPG
Iron: 0.2
Manganese: 0.16
