fandi
Hello All,
I installed a Fleck 5600SXT 3 years ago. The system works fine until recently not enough water coming out of the Fleck. Since last month, 2 showers at the 2 bathrooms can't be used at the same time as little water would come out from both showers. Yesterday, while no one in the family uses water from showers/faucets/toilets and still not enough water to feed the washer (I got 'nF' code from the Samsung washer). Switched to bypass and two showers can be used at the same time or the washer can run just fine.
Can you tell me what parts of the Fleck would cause the problem?
Thanks.
Thanks.
