The SXT digital controller, is equipped with non-volatile memory to preserve the programmed settings.
Time of Day is preserved for up to 48-hours, powered by a built-in rechargeable battery or capacitor. When the clock displays 12:00 either steady or flashing, that is a common indicator the power outage exceeded the power available from the battery or capacitor.
To reset the time, see video posted here:
How to Unlock and Change the Time
To set the current time and get the clock moving again, follow these steps:
- Press and hold either the Up Arrow or Down Arrow button.
- Keep holding the button for about 3 to 5 seconds until the service icon disappears, a programming icon (looks like a finger pushing a button or gear) appears, and the letters TD (Time of Day) show up on the screen.
- Use the Up or Downarrows to adjust the numbers to your current local time.
- Crucial Step: Keep an eye on the PM indicator in the top right corner of the display to make sure you do not accidentally set it to AM instead of PM (or vice versa).
- Once the correct time is reached, press the Extra Cycle button (the button on the far left that looks like cycling arrows) to lock in the time and return to the home screen.
(Note: If you don't push any buttons for 5 seconds after adjusting the numbers, the system will save your changes and exit to the home screen automatically.)
What if the buttons won't respond?
If holding the arrow buttons does not bring up the TD menu, your system might be stuck mid-cycle or waiting for a regeneration. Press and release the
Extra Cycle button once to let the system cycle through its internal checks, and then try holding the arrow keys down again.
