William Yasment
There is no water in use as this indicator blinks and it also affects the rate of supposed use therefore regeneration of the unit.
I have had this unit apart cleaning out valve controls and examined the turbine. Although the turbine cable seems to fit loosely, with water flow always on, it would seem the cable is bad or is it the board itself?
Age of the unit is 5 years.
Maybe where the cable connects to the board? If so, how does one take apart the head to have access to the connection.
Thanks
Thanks
