Leighman
Hi Everyone,
I’ve spent a day reading, and think I have most of this figured out, but need to run what I’ve come up with by you. I apologize for the length.
I’ve had a Fleck 5600 Econominder for many years on a 10x54 resin tank with what I assume is 1.5 ft^3 of resin. That tells me it is 48k grain system. However the salt setting is 12 lbs so / 1.5 ft^3 that means I’m using 8 lbs of salt per... ? Something...
(In reading further I’m coming up with a 48,000 capacity at a 12lb salt setting gives 40,500 of regen capacity, but again, not sure if I should go higher or lower.)
Anyway, it died. Resin was low and I didn’t know until I saw the brine tank full of water.
My softener guy suggested renting a new digital unit at over $400 per year, or buy a rebuilt 5600 head and 10x54 tank for $2300. In the meantime he installed a rebuilt control head and tank with now no mention of a new digital unit, and wants the same $400 a year. The replacement head actually looks older than the 12 year old head it’s replacing, but it works.
I think I can figure this out and buy my own and install it.
His settings: 12 lbs of salt, 3 people at a hardness setting of 20, regen just under every 1200 gallons. I think that’s too much, and after reading think I have been wasting water all these years.
My math: 3 people, 60 gallons per day, water company says I have 17.2 grains of hardness (294.55 ppm). 3*60*17.2, call it 3100 grains of hardness per day. 40,500 / 3100 = 13 Days, but round to 12 for safety margin.
12 Days at 180 gallons per day = 2160 gallons per regen.
I think the softener service just uses the people wheel and 20 grains of hardness across the board, so I’m regenerating more than I have to at 1175 gallons or so, approx. twice as much. (Once every 6.5 Days rather than once every 12.)
I know the people dial also assumes 75 gallons per day, but I think 60 is more realistic for us. For now, I used the people wheel to move it to 17 grains of hardness for 3, which took me up to around 1300 gals till regen. Still too soon I think, but don’t want to go way higher to 2100 without understanding and checking.
What I’m still confused on is that salt setting of 12, (which works out to that same factor of “8” which is the number I don’t understand) and what it would mean for my salt / water usage if I messed with it.
We’re going to be here a few more years, so rather than rent or pay full boat for a used and rebuilt head, I’d like to buy a similar head and tank that will back up right to the plumbed fittings. I believe they are 1” inlets, based on the OD of the pipe.
I just need to understand the different control head functions regarding regeneration and backwash and brine fill to know exactly what’s happening rather than taking it for granted.
Thanks very much for checking my math and taking the time to slog thru all the above, and for any input.
