Fleck 5600 - Injector Drain - Excess Water
Lynxxs
Florida
Hi all
I have a Fleck 5600 12 Day
Originally, my system was not working I noticed the main gear had some broken teeth, so I replaced the main gear, piston, seals, and brine valve. The piston seals replaced were deteriorating with small rubber prices everywhere even flushing though the main faucets for a bit after the rebuild. A month or so later, I noticed my brine tank was full of water. I dumped out all the old salt and cleaned the brine tank and after some testing my brine tank is filling when it should be sucking the water out. I wanted to remove and inspect the injector drain thoroughly but a steady steam of water constantly pours out. The bypass is on and I backwash the system right before working on it. Why am I getting so much water?
