ditttohead
Water systems designer, R&D
Not sure what that means. Please describe what you are talking about.
I can only guess.. the refill of 7 gallons in 14 minutes would indicate you have a .5 gpm refill button. If your system has a salt bridge the water will be below the salt. This is easily determined by kicking the lower section of the brine tank. If it is hollow then you may have a bridge. You can also disconnect the brin line from the valve and suck some water out of the brine tank (Nasty!) but it works. If it is salty then all is well. The water will usually dissolve an adequate amount of salt in only 10 minutes. An hour is recommended.
