BMWpowere36m3
I just want to verify what actually is flat venting. Below are a few models showing a basic drain, p-trap, trap arm, vent arrangement. Which are considered flat vents?
First up is what I think (based on forum comments) is the preferred "method" of venting, horizontal trap arm into a sanitee and the waste goes down and vent up.
Vertical
What if your horizontal trap arm connects to a horizontal waste line and there is no vertical drop... you put in a wye or sanitee (on its back) and vent straight up off the horizontal trap arm. Is this a flat vent?
Vertical, but should be a wye on it's back, not a santee
If the above is okay... then the below should be okay as well. Sanitee or wye rolled up at least 45 deg (considered vertical).
45 degrees is vertical, but should be a wye on it's back.
What if you put the sanitee or wye exactly horizontal is it a flat vent? And/or an issue because you are not locating the vent opening above the centerline of the waste line?
This is flat.
Or is the last one a flat vent because the vent line goes horizontal before being 42" off the floor or 6" above the flood rim level of a fixture..
This is also flat when it is no longer at a 45
Any fitting on the horizontal should be a wye or combo.
Vertical
This is flat.
