Fix toilet flange in concrete or leave it?
CBme
Kirkland, WA
Getting ready to do a levelling pour on bathroom floor but need to decide what to do with the flange first. The floor shouldn't be raised up here by the pour, as it the high spot, but if I should fix the flange I want to do it prior to leveling. As you can see in the images they put it flush to the concrete.
Obviously this can (and has) worked with 1/2"-3/4" flooring, via flange extender and Fernco wax-free seal, but it is not obviously not desirable or correct to have not be flush with the finished floor (or on top of it). It appears to be the external fit to the 3" pipe which seems to make removal extra difficult as I'd have to be able to get to the outside to cut it off.
Looking for suggestions as to whether to leave it or not, and if not, how best to approach the difficulty of removing it to add a new one (that can go up an inch)?
CBme
Kirkland, WA
The original flange, tho steel, looks pretty good. I would add an Oatey Extender Kit to bring it up to your new desired level. I prefer my flanges to be flush or just slightly proud of the finished floor.
Yes, there isn't any noticeable rust or other degradation on the metal flange so it doesn't need to be replaced for that. It would only be to go through the effort to make it how it should have been done in the first place. Doesn't seem to be a trivial amount of work as it is embedded in the concrete and there is risk to damaging the main pipe so I'm vacillating on making a decision.
I would add some Tapcons to hold the ring down to counter the upward force from holding the toilet down.
I like looks of the extender kit. only thing is those screws look like they might not be much fun on a slab. Certainly a good option it seems under right circumstances
CBme
Kirkland, WA
Thanks everyone. I'll leave it, add screws and/or concrete epoxy to help hold it down (pipe is in concrete is what is what was holding it currently), and use extenders.
its a common issue That the flange is simply glued on and not secure to concrete . it saves time to skip a step
