BarkityBark
I have 2 single-handle Delta shower controls in two showers in my house and neither one regulates the hot water correctly. I've cleaned and changed out the valves (RP19804), but this did not solve the problems.
In one shower, pure hot water will not come out of the shower head (it only gets luke warm), but it comes out of the spigot hot. In the other shower, pure hot water will not come out of the spigot, but comes out of the shower head hot. Frustrating!!!
The house has a hot water circulating pump system, if that makes any difference. Also, the cold water supply pressure is on the high side. Perhaps hot water pressure compared to cold water pressure an issue here?
And yes, the scald adjustments are already all the way over to "hot".
Unless someone can come up with an answer, I will be forced to tear out the single handle Delta's and go with a 2-handle valve. If you recommend this option, which company makes a mid-priced model which is worthy?
