Fitting solvent weld p-trap to tub drain
Jetboy55
Wisconsin
I'm installing new pvc trap arm to my existing tub. Also replacing the tub drain and overflow assembly, using a new t-waste drain assembly from Jones Stephens. I'm also using a standard solvent weld 1 1/2 in p-trap. Not having done this in over 15 years, I realized there is something I don't know. Will the 1 1/2 in pvc p-trap mate up to the tub drain? Is so, will it also be a solvent weld connection?
John Gayewski
Iowa
It depends on which tub drain (shoe) you buy. There are different types.
Tuttles Revenge
If its this one.. Yes. Solvent weld.
Glue it up Jet boy! 1 1/2 should be good unless its a long trap arm Not that common to require 2 inch.
Jetboy55
Wisconsin
Yeah, thanks for the help. That is the one I ordered due to an obstruction. It is 1 1/2, and I'm just under the maximum length in Wisconsin. I forgot that the drain fitting is basically a san-tee.
I thought the santee was a seperate piece but I guess not with this kit . It should function fine maybe even better We just dont do it that way unless an issue like you hase
