CKPLUMBING
Hey everyone,
Just got done with a test fit of a second floor bath and washing machine drain system. Was hoping for a sanity check. The wall hung toilet drops directly down into the short sweep you see at the beginner of the 3" line.
From the back to the front, there is a sink, which pick up the drain from the washing machine (both of which are 2"), which then joins the toilet's drain pipe, which picks up the bathtub's drain that has to be drilled through the joist. It all then makes a turn vertical to go down into the basement.
The vents are marked with red Vs. Also added a picture of it up in the joist bay.
Does anyone see any issues with this? Any advice is appreciated!
