First look -- Pentek Big White w/ Bypass
Lee_Leses
Pennsylvania
After quite a bit of searching, I was able to buy one for a deeply discounted $48.
The way the main housing o-ring is designed to seal looks good -- same as the Pentek Big Blues.
The housing is designed to be supported by only the pipes it's mounted to?
I don't fully understand the construction of the bypass valve, or how it's assembled? Does this design look good or bad to someone with more trained eyes?
The rubber o-ring seal on the bypass valve reminds me of Sharkbite fittings -- will this design hold up over time?
See pics!
they make brackets for the big white you might want to contact or order the correct bracket Pentair is a major manufacture of this stuff and pool equipment so I'd expect the product be decent I've installed filters but don't know which brands. cant vouch for the quality
