fire resistant plumbing vent?
VinceBlue
Sherbrooke, Qc
Hi everyone,
I need your help. I don't really know how to explain the problem and my first language is French, please be indulgent. :)
I live in Quebec. My house is the first unit of a 3 unit townhouse. My two neighbor's plumbing vent are hooked on my stack vent. (please see illustration below)
Each unit is separated by a 1 hour rated fire resistant wall. The problem is that in the attic, although the walls are constructed to be fire resistant, holes were cut in them in order to pass the plumbing vent for the other 2 units making the walls not fire resistant. :rolleyes:
My question is: does the code allow the installation of a horizontal self-closing fire resistant vent apparatus (I don't know how to call that "thing.") between my 1st neighbor and me? Does that "thing" exists?
Thanks everyone!
Vince
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Most often, metal...most often cast iron pipe is used in fire resistant construction, and then fire caulk finishes the seal.
That is how a fire resistant assembly is done.
John Gayewski
Iowa
There are special collars that can be installed in the hole that the pipe will pass through. The collar will expand and close the hole if there's a fire and the pipe is pulled out.
But generally you'd use cast iron to pass through the hole and normal fire caulking.
Tuttles Revenge
Tuttles Revenge
We were working in a commercial strip mall and the fire walls had been badly damaged without any repairs over the years. The contractor we were working for made complete repair of the fire wall between our client and the rest of the building. We were coming to work on Monday and the entire building was burned to the ground except for the part that had been protected by the fire wall.
wwhitney
Berkeley, CA
FWIW, the OP needs to check the applicable building code. I believe there are situations in which zero penetrations are allowed, in which case the correct solution is to have 3 separate roof penetrations and to fully repair the firewall penetrations.
Cheers, Wayne
